12v power source?
Old Jul 9, 2004 | 02:58 AM
17WITHaBIRD's Avatar
Default 12v power source?
i am looking for a 12v power source in the dash that is switched. i need it to power some leds but i do not want it to always be on or "hot". i was thinking the radio but im not sure if that would work. also i have a 94 trans am. not sure if the wiring stuff is the same with the ls1 and lt1 but thought you guys could help. thanks
matt
Old Jul 9, 2004 | 03:04 AM
badjuju342's Avatar
Deranged Rat Fink
the yellow wire in the radio power plug is switched , the brown wire in the ignition switch harness is "key on" accessory , the orange wire in the ignition switch harness is also"key on" accessory , the pink wire in ignition switch harness is "run" wire , or you could just use a spare terminal in the fuse box ,lots of options there.
Old Jul 9, 2004 | 03:51 AM
thanks.....i think the radio might be the easiest for me to get to
