A/C Help - Throwing P1545 and P1546 codes - SOLVED
Looked into the tune and found that the tuner had disabled the following codes for A/C:
• DTC P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
• DTC P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
• DTC P1539 A/C Clutch Status Circuit High Voltage
• DTC P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
• DTC P1546 A/C Clutch Status Circuit Low Voltage
After starting the car and scanning, the following two codes appear:
If I clear the codes, P1545 appears without the AC being turned on, and I can make P1546 show up by commanding the AC clutch on from within HPTuners. Right now I'm at a loss, looking for help/suggestions. (WhiteBird00 - if you're looking at this, the car is a '98 TA, still on original PCM)
Two items of note:
1. While mechanic was trying to sort out the issue, I saw a huge spark while he was poking around near the compressor (not sure if that's helpful or not)
2. I brought the car to a local dealership for estimate recently, not sure if they did anything while the car was there, but just putting it out there.
Props to WhiteBird00 for the reminder to check/verify/rule out the simple stuff first.
