driverside power window.
I currently have a 2000 ls1 trans am, my driver side power window was not going up every now and then, now it is just stuck down, i have checked the fuse/relay, and i have removed the body control module to re solder the radio/window points that are giving some people issues and nothing works. The window was not straining or slowing down before it finally stopped working so that makes me think its not the motor. Do you guys have any other suggestions or info that i am unaware of, should i just change the window motor out, if so what size nuts and bolts are being used after you drill out the rivets? Please any help would be greatly appreciated.
