Improving mid-bass from door speakers
Ungrounded Moderator
No, the difference between twisted pair and shielded coaxial (RCA) is measurable but not significant enough to be audible in such a (relatively) short run unless you run your wire right next to unshielded wires that could cause magnetic interference. As long as you follow the best practice of keeping your power and audio wire runs separated, either one will do an admirable job. Buy whichever one is most affordable... there is no truth to the story that specialty wiring (like Monster) is better than basic wiring. Only buy the fancy stuff if it's exposed and you want to show it off. Otherwise, basic Amazon wire and similar brands will work just as well.
Not really. Audio signal is alternating current so unlike DC where you have separate power and ground, both wires would show varying voltage. You could do it with an oscilloscope but that's not practical. If it was the factory wiring you could just go by wire colors. With your own wiring you'll just have to confirm that the polarity at the source end matches that at the speaker end. From a standard aftermarket head unit, the front speakers would be the white wires (left) and the grey wires (right)... the plain wire of each pair is positive and the black stripe wire is negative.
I have an Alpine head unit booster amp that I was going to try, so I might as well put that in since I need to check the speaker wires.
Has anyone else done this, I bought a small amount of sound deadening material, not sure if I should put it in the doors, sail panels, or behind the stealth box that will be installed on the driver side near the t top holder?
