Hatch Latch Resistance
It isn't too hard, but it requires you to use a volt-ohm meter. If you can, here are the steps:
- Open the hatch and pull the lining over the lower latch so that you can see the wiring around it.
- Find the 2 wires going straight out of the bottom of the latch (not the ones on the side for the solenoid).
- Unplug the connector. There is a clip on the side, but it is very easy to lift with just your fingernail, you don't need tools.
- If you look inside the connector coming from the latch, there should be 2 pins.
- Take your volt-ohm meter and set it to read resistance Ω around the 20K setting should be fine.
- Touch one probe to each of those pins, making sure not to let the probes touch or it will alter the reading.
- If it says "1," that is infinite resistance, meaning open switch/circuit. If it goes to 0 or near to it, that is a closed switch/circuit, which is also what it will show if you touch the probes together. Let me know what you get on yours.
- Repeat the process, but this time get a reading with the trunk closed (careful not to pinch the trunk lining in the latch). You will either have to fold the back seat and crawl over it, or you can fake it by latching a screw driver into the lower latch to artificially close it. When you finish probing, use your key or remote to get the latch open and lift the screw driver out to reset the latch if you use this method.
- Again, take a reading, this time with the trunk closed, and let me know if it is 1 or 0.
