delco 12 cd changer
Old Jul 13, 2004 | 05:31 PM
ssam98's Avatar
Question delco 12 cd changer
I have a 98 ss camaro and my car came with the low in radio, not monsoon. does my car have the harness for the cd changer, yes no help.
Old Jul 13, 2004 | 08:02 PM
WhiteBird00's Avatar
Ungrounded Moderator
I don't know off hand but it's easy to check. The harness (if it's there) is taped to the left rear speaker harness under the plastic trim in the hatch area. You can just reach up under the trim panel and check if the harness is there.
Old Jul 13, 2004 | 08:41 PM
ssam98's Avatar
Default 12 cd changer
I did not find any theing their.
Old Jul 13, 2004 | 09:39 PM
ssam98's Avatar
Default 12 cd chqnger
Any body is a 98 camaro NON monsoon unit come with cd harness help anybody thank you.
Old Jul 14, 2004 | 02:41 AM
badjuju342's Avatar
Deranged Rat Fink
know a guy that has the monsoon head unit , changer and amp with the speakers and harnesses for sale , he's parting out a 99 T/a that got wrecked , go to the classified section at www. mtfba.org and look for NOR_99TA , he's a good guy and honest , the T/A was his baby till some dude pulled out in front of him at fifty miles per hour,OUCH!
Old Jul 14, 2004 | 10:37 AM
If you checked behind the left rear speaker and there was no harness there then your car didn't come with one. You'll have to check on the back of your radio to see if it even supports an external CD changer. If it does, there will be an extra 9-pin port on the back for the harness.
If your head unit supports a changer then you can buy the one mentioned above or you can usually get them with a harness included on ebay.
You can always make your own harness. The pigtails for each end are available from your dealer or gmpartsdirect.com. The front 9-pin pigtail for the head unit is part number 12102629 and the rear 10-pin pigtail for the changer end is part number 12085486.
Old Jul 14, 2004 | 05:06 PM
ssam98's Avatar
Default part number for harness 12 cd changer
I need the part number for 12 cd changer harness.
Old Jul 17, 2004 | 02:01 PM
ssam98's Avatar
Default harness
I want thank every body for their help i found the part number for the harness to cd changer # 12344015
