Guage cluster lights dont light
The instrument cluster illumination is six bulbs wired in parallel with a single power and ground connection. The power feed is the gray wire at the bottom corner of the cluster connector and the ground is the black wire right next to it. Your next step would be to pull the cluster and check those wires for proper power and ground. That will tell you if the problem is with the power source and ground or something internal to the cluster.
Also how would i test this wire? Do i need to take some insulation off or can I just use my multimeter as is
If you can't get that kind of access to the connector then you can try just going by position. The gray wire should be in the bottom row in the second to last position on the right. That is "should be". The pinout diagram I found is for a 95, shows the connector inverted and does not say whether the pin numbering is from the front or back of the connector: http://shbox.com/1/95_ta_cluster_pinout.jpg. The fact that it's a gray wire is the same for all model years but I can't guarantee that the position in the connector didn't change.
You should not need to remove any wire insulation - in fact, that would be a bad idea. You should be able to make contact with the metal wire terminator in the connector using the meter probe. This is where a test light is better than a multimeter because they usually have a finer tip that helps ensure you contact only the circuit you aim for. Be very careful not to allow the probe tip to contact the gray wire and the black wire next to it at the same time. That would blow a fuse because the black wire is ground.
