Installed new dash cam
You can see it's hardly noticeable at all from the outside:
For the rear cam, I simply routed the wire above the headliner leaving enough slack out the back to open and close the hatch without creating any tension. The wires for the front cam also start above the headliner, then down the A pillar into the dash. The power and accessory wires go to the fuse panel and the ground goes to the ebrake bolts. You can see the GPS antenna mounted to the right of the rear view mirror, instructions said it needed at least 15cm from the cam.
I think it looks great and so far works perfectly. I'll be interested to see if the adhesive survives the summer...
Unrelated, but those don't look like the original headliner or mirror. Looks like microsuede material and I'm not sure which mirror.
The headliner started to sag a few years ago so I had it reupholstered with micro suede, good eye. The mirror however is original as far as I know. The car has only had 1 previous owner: my uncle. I'm pretty sure he never modified or replaced anything except the stock radio a few times and the water pump a few times.
