What connectors are these?
Old Jun 21, 2021 | 09:45 PM
JaceDaniel83's Avatar
Default What connectors are these?
They come with the electronic cut outs. They are like rca connectors but bigger. Needing to know the name of them? Any help would be appreciated.
Old Jun 22, 2021 | 01:30 AM
VIP1's Avatar
Copy & Paste Moderator
Those are standard barrel connectors. You need to know the diameter of the barrel and the pin. The most common is 2.1mm or 2.5mm Pin x 5mm or 5.5mm Barrel. Sometimes a local parts electronics parts store will have a test board or cable-set so you can test fit. It's the same thing as on many power bricks, but you need to know the right size for a good fit and connection.
Old Jun 22, 2021 | 04:45 AM
thanks a lot. I appreciate it
