01 ws6 coupe. Trunk release click
Old Jul 7, 2021 | 08:03 PM
Pbarby's Avatar
Default 01 ws6 coupe. Trunk release click
Spring mod in place. Shocks good. Only get a click when using fob or button to open trunk. Even if I press down on trunk lid or pull up while pressing only getting one click per button press.
if I need a new motor, where can I find other than used on eBay? Rebuild thread?
Old Jul 11, 2021 | 01:01 AM
Pbarby's Avatar
Part is called Lock Actuator
part # 16634740
around $40 delivered from gm dealers
Old Jul 11, 2021 | 05:24 AM
ARSENAL670's Avatar
Is this about the release not releasing on the first press of the keyfob button or the dash button? Curious, because it takes 2-3 presses of either button to pop the trunk up enough for me to be able to lift it open. Not sure if this is a common problem, or if this is the solution to that.
Old Jul 11, 2021 | 08:26 AM
Pbarby's Avatar
Mine wasn’t in latching at all. I heard a click at the trunk and on inside the car..no matter how many times I pressed the button on the fob or inside the car it wouldn’t unlatch.
I opened the trunk by unbolting the trunk latch from inside the car. I detached and reattached the wire/harness then it worked.
