Under dash or hidden antenna?
Old Sep 9, 2021 | 08:47 PM
nickp's Avatar
Default Under dash or hidden antenna?
I would like to eliminate the factory T/A stereo antenna for a cleaner look. Are there any hidden or under dash options you guys recommend? Just looking for basic local FM channels. The reviews I've seen are very mixed. Thanks.
Old Sep 10, 2021 | 12:59 AM
VIP1's Avatar
Copy & Paste Moderator
https://ls1tech.com/forums/wiring-st...m-antenna.html
Old Sep 15, 2021 | 04:12 PM
VIP1's Avatar
How'd this work out?
Old Sep 17, 2021 | 12:23 PM
nickp's Avatar
Thank you sir. I am scared to take the dash pad out lol. but this is the info I was looking for.
Old Sep 18, 2021 | 08:11 AM
wssix99's Avatar
Save the manuals!
Look at posts 22-30 in the link above. You can put the antenna on the front edge of the headliner. It's really easy. The headliner actually goes up to the glass so the antenna ends up sitting right by the tinted band at the top of the windshield. (vs. under the metal roof, where one would think it would end up, being attached to the headliner)
Old Sep 26, 2021 | 10:31 PM
j498's Avatar
If you get one of the wire FM antennas that you have to roll out from either end you can get it under the dash by taking the radio bezel and feed it to the left behind the dash cluster (must be removed), and to the right above the glove box. Won't be perfect but it works OK and is something. I did this and used painters tape to hold it to the highest point under the dash as possible.
Amazon Amazon
