93 TA VAT issue
Let's start with where the resistor is installed. Here is a photo of the sensor wires connector near the base of the steering column:
VATS key sensor wires
You want to have that connector unplugged and the resistor inserted across the white/black and purple/white wires (soldering is best but any method which ensures a tight connection will work). Some people cut the connector off and then use crimp connectors to connect the ends of the resistor to the wires. Of course, make sure it's all insulated with electrical tape or shrink wrap to avoid any possible shorts. The other end of the connector with the two white wires in the orange sheathing should be left disconnected and tucked away out of sight.
The other question is where are you taking your reading when the resistor is installed? Taking it directly across the ends of the resistor should give almost exactly the value of the resistor. Checking it at the BCM will tell you what VATS is seeing which could be different if there is a problem in the wiring. That would be an immense help if everything else checks out.
You need clean surface for measuring with a meter and for soldering. Looks like solder globbed around black goop. That will lead to a bad connection and increased resistance.
If I'm reading this right... looking at the bands on that resistor...
Violet = 7
Green = 5
Black = 0
Brown = x10
Which totals 7500 ohm
So I guess your meter read that right.
If your key is reading half that and that let the car start, but the key is half that and the car won't start with that key, then that is the wrong key and you should ignore its value. You might have a bad connection instead.
Violet = 7
Green = 5
Black = 0
Brown = x10
