Opinions:. Components vs separates + DSP
Would you really be able to tell the difference?
I am running active through either the head unit or amp crossovers while utilizing the EQ as well. I haven’t decided which crossovers to use yet, might possibly even run both but I’ve also seen a scenario called stacking that I’m a little concerned with. On my set up each speaker has its own individual bridged channel with RMS and ohms matching perfectly to one another. I might have described what I’m doing in another one of your posts but can’t remember.
Alpine iLX 507
JL XD700/5: Channel 1&2/3&4 mids at 200w each to Hertz SPL show 6.5s. Channel 5 at 300w to JL 10W1 in stealth box.
Alpine KTP-445U: 1&2/3&4 highs at 90w each to SEAS 27 1” soft domes from Madison sound (which fit the TA pod perfectly). At their advice they are protected by CalrityCap PUR 8.2 poly caps which they set me up with as well.
When you go active (DSP or not) it opens the door to go a la carte and pick what you want based on specs while not paying for crossovers in a kit as well. I’ve yet to install all of this however I’m really looking forward to the results. Everything all over the car is still in process but it’s coming along slowly and I’m hoping to have it running soon. If you’d like to hear it we can meet up sometime.
Alpine iLX 507
I don't like front staging. I feel like it takes your forward focus away from driving.
I am going with 6.75 mids and 1" tweeters in the doors stock location, 6.75" subs in the sails, 5.25 mids and 1" tweeters in the hatch stock location, and a 10" sub in a stealth box.
AudioControl 10 channel DSP, and likely Rockford Fosgate fan cooled amps.
Personally, I would recommend saving some money with all of the separates and focus on a good quality set of components for the doors. Unless you look towards the trunk of the car frequently while driving, I would think that the mid and tweeter would be kind of a waste. More speakers is not always a good thing, whether there is a factory designated location for them or not. The money you will spend on what you have listed would get you an incredible sounding set of components, and once you get into the higher tier of speakers they will either have crossovers that will be capable or you can purchase many sets without crossovers if you are dead set on running active. To most (probably 95% or higher), there would not be a discernible difference between the two when properly tuned.
A single amp can power your entire system, again quality over quantity. With the design of the car, the hatch area lends itself extremely well to the lower frequencies of a dedicated subwoofer which at this point would render the mid-sub in the pillar practically useless. With that said, my opinionated recommendation would be a good component set in the doors, a coaxial for rear fill either in the pillars or hatch area, and a subwoofer in the trunk. I'm all for the capabilities of a DSP over just running a head unit output to the amp(s). I just hate seeing an unneeded amount of midgrade equipment (too many amps, too many drivers) that could be easily outshined with half as much.
I was thinking that the 6.7 woofers in the sails would be specifically for higher bass frequencies, maybe 80hz to 200hz, and the sub would handle 80hz and lower
If you can find a shop that has some better quality drivers that you can demo, I think it will definitely be worth the time. Morel Virtus are a great sounding, fairly priced set that I highly recommend hearing if possible. Even in a 4" component, these can have stronger midbass output than a majority of the more widespread brands I have used in a 6.5/6.75. I'm assuming you had a Monsoon system, and much like Bose, JBL, Harman Kardon, Bang & Olufsen, Mark Levinson, and others, I rip that garbage out first chance I get. I'm in it for the music, and have yet to be truly impressed by any of the OEM manufacturer's offerings in this regard. The reason being is that they are trying to emulate what an amplified system can be, but they do it by exaggerating the midbass and midrange frequencies and the layouts of their systems mirror that. There were midbass drivers in the sails because they didn't have a subwoofer (6" is not a subwoofer, even an 8" is generally a midbass driver to me), once you have a real subwoofer they are irrelevant.
However, everything is subjective to what "good" sounds like to the individual. My opinion may be polar opposite of what you are going for soundwise. Anybody trying to sell you something specific will have a biased opinion based on their financial gain for the most part, I just want you to be able to experience the music while beating on that 434.
