Alternator warm and buzzing when car is off
Old Dec 20, 2023 | 10:03 AM
jmilz28's Avatar
Throw an alternator on it, a Powermaster HO unit is your ticket. These cars' 105a OEM units were barely adequate. 04 Escalade unit is a cheap upgrade too.
Old Dec 20, 2023 | 10:25 AM
Austin_Jim's Avatar
The CVF units have a lifetime warranty, so I have to start that process. And their units are 170 amp. Once I replace, I'll see how it goes. I have a rather large stereo in the car as well. If I run into issues with the lights on and the stereo up, I'll go with a Powermaster or Mechman
Old Dec 20, 2023 | 02:07 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I second the Powermaster recommendation, if the warranty route doesn't work out. Powermaster is a quality product, it's the only brand of aftermarket alternator I will buy.
Old Jan 8, 2024 | 08:30 AM
Austin_Jim's Avatar
CVF is warrantying the alternator no questions asked. GREAT service. As soon as I get the replacement installed, I'll report back.
Old Apr 24, 2024 | 11:14 AM
2ARon's Avatar
Been following this thread. I have same issue. Did replacing alternator solve the problem?
Old Apr 24, 2024 | 12:50 PM
Austin_Jim's Avatar
Unfortunately, I do not know yet. With car show season, I haven't been able to swap it yet. After I drive it, I remove the main battery wire and put it on the battery tender. Should know in a month or so.
Old Aug 17, 2024 | 12:56 AM
evlfred's Avatar
any updates. Having the same issue with my CVF alternator on my blueprint engine
Old Aug 17, 2024 | 07:44 AM
Austin_Jim's Avatar
Sorry man. Not yet. I'm waiting to get through show season before I replace the alternator. If I disconnect the battery after driving and put it on the trickle charger, I'm good, so it isn't a big deal. And I have to take out the radiator and fans to change, so it isn't a quick job. I will update this thread as soon as I do it. It'll probably a few months before I repair it.
Old Nov 23, 2024 | 12:20 PM
Austin_Jim's Avatar
Finally got to changing the alternator. I had to take out the radiator and fans. They were so close to the tensioner I couldn't fit a breaker bar in to loosen it. Radiator's out, swapped the alternator, but noticed something interesting. The serpentine belt it rubbing on the upper body of the tensioner between the A/C and tensioner. Ordered a couple shorter belts so the tensioner will sit further away from the A/C. Just waiting for them to get to my local O'Reiley's. Should have it buttoned back up tonight or tomorrow. I'll let y'all know how it goes.
Old Dec 28, 2024 | 03:20 PM
Austin_Jim's Avatar
TL;DR - I'm 95% sure the alternator was the issue
Got it buttoned up a couple weeks ago. Seems to have solved the problem. HOWEVER, it appears I cracked the belt tensioner when I was taking it apart and of course didn't notice until I had it all back together. About 3 minutes into the test drive, I heard pretty bad "clacking" sound. Got it home, left it running and pinpointed the noise to the tensioner. Called CVF and they sent a new one on warranty. Can't say enough good things about that company. Took it apart again today. Sucks because I have to take out the radiator and fans to do so. Replaced the tensioner and all seems to be working. As far as I can tell, a bad alternator from the factory was the issue.
