Power antenna issues
The new Antenna actually matches a wiring diagram, wire colors are gray on one side, green in the middle and white on the other side. I have tried several different combinations of where to put the wires, sometimes it will go up or down, but not consistent, any help would be greatly appreciated.
99 Trans Am
Other than that, I don't have a lot to offer other than trial and error. It's probably safe to assume that the ground wire does not go to the middle pin since that's the factory configuration. So, you can try connecting one outer pin to ground and both of the other pins to power (use jumpers connected directly to the battery or a bench power supply to eliminate any possibility of bad power or ground) - the antenna should extend and stay extended. If not, swap the two outer pins and see if that works. The only other possibility is the unlikely setup of the ground being the center pin.
If none of those combinations work then the antenna is faulty... it will be up to you to convince the vendor that you didn't break it.
If you find a working combination then you'll only have to determine which power needs to be constant and which is the signal. Simply remove one power wire and see if the antenna retracts. If it does then that's the signal wire, otherwise the other power wire is the signal.
