BCM removal help 02 T/A
Old Jan 2, 2025 | 03:04 PM
rocket dawg's Avatar
Default BCM removal help 02 T/A
I located it under the glove box. First I removed the kick panel on the side, then the panel under the glove box. It appears to be stuck. I cant even get any of the plugs apart. It will wiggle, just barely. I dont want to break anything by yanking on it. How are the plugs removed? I used a mirror and dont see any "locks" on the plugs. Are all the plugs to be pulled apart first? i watched a ton of videos on it and Im still kinda lost. thanks
Old Jan 2, 2025 | 04:08 PM
I found another thread on this site. Also found some you tube videos that might help
https://ls1tech.com/forums/general-m...ms-fix-13.html
Old Jan 2, 2025 | 04:39 PM
You tube video
