Quick monsoon wiring/speaker question.
So if 10ish watts is worth taking your door panels apart and you have an aftermarket HU, just switch the tweeter and driver plugs, wires are long enough and you dont have to splice anything.
I thank you for physically demonstrating what I've been saying for many years - the difference between 2-ohm and 4-ohm when replacing speakers is quite minimal and not worth worrying about (as long as your source is stable at the lower impedance - some amps can't handle 2-ohm speakers).
A couple of side points... your comment about the tweeters and inline high pass filters applies only to Firebirds, Camaro tweeters are powered and filtered by the Monsoon amp. And never compare output using peak watts as there is no standard on how that is measured - I tend to refer to those readings as "watts ILS" (If Lightning Strikes). Using RMS wattage is a standard which will ensure an apples-to-apples comparison.
but i feel what would be helpful to alot of people is if you want to run full range speakers in the sail panels and have an aftermarket deck (or even factory), just tie into the tweeter channel in the hatch and just run whatever speakers you want in the sails
The Monsoon amp producers 240 watts RMS into eight channels, so about 30 watts RMS per channel. But that's an average as the amp actually produces more power to some channels than to others. The tweeters (Camaro systems) get lower output because it's not needed (Firebirds produce the same lowered tweeter output by running them directly from the head unit). Similarly, the sail panel subs get the bulk of the power by design simply because subs need more power (again, Firebirds emphasize that difference by running two channels to each sub).
Close but not quite... The 4" speakers in the hatch area of Monsoon systems (in both Camaro and Firebird) get full-range unfiltered signal from the Monsoon amp whereas the tweeters (Firebird only) get signal from the head unit. So if you want (for whatever reason) to run full-range speakers in the sail panels then using the 4" mid wiring from the hatch area would be better than the tweeter wiring because you get more power. Of course you'd be moving the sound stage away from the front, as well as giving up significant bass, especially in the dual voice coil equipped Firebird.
