BCM and lighting?
Old Oct 25, 2025 | 08:41 AM
Bruthajoe's Avatar
Default BCM and lighting?
Can anyone confirm the duty of lighting control through the body control module?
I've recently noticed my signal lights go wonky along with the common window and radio BCM symptoms.
Whacking the console on the right side usually gets it all back but I plan on reflowing the board and
I'd just like to know if it's a coincidence or related before I get in there.
2000 Firebird Formula
Old Oct 25, 2025 | 10:00 PM
WhiteBird00's Avatar
Ungrounded Moderator
The BCM is not involved in the turn signals in any way. It manages the interior courtesy lights and the flashing of the external parking lights as part of the keyless entry and optional alarm systems, but not the signals.
Old Oct 28, 2025 | 06:18 AM
Bruthajoe's Avatar
Ok So there is no chance the BCM malfunction can affect the running light circuit??? There must be something else under the dash causing the problem.
I'm all ears if anyone has a guess. To recap The problem is intermittent loss of and erratic voltage to the (amber) signal/running lights. Smacking the console like Fonzie from Happy Days can fix it.
Old Oct 28, 2025 | 09:32 AM
Well yes, I suppose it is possible for the BCM to affect the running/parking light circuit since it controls flashing them for the alarm/keyless entry. What I said was that there is no way for the BCM to affect the turn signal circuit. There are two filaments in each of the lamps involved and each filament is on a different circuit. The dim filament is used for the running lights (when the headlights are on) and the parking lights (when the headlight switch is in the P position) and those are the lights which are flashed via a relay by the BCM for locking/unlocking the doors by remote and for arming/disarming and activation of the optional alarm system. The bright filaments in front are used for turn signals and daytime running lights (DRLs). In back they are used for turn signals and brake lights in Firebirds or just brakes in later model Camaros with separate amber rear signals.
Please describe in more detail the symptoms you have. Do the lights fail only when the the turn signals are on? Do they also fail when the hazard flashers are on? Do they flash unexpectedly when the signals are off? Or flash the wrong side? Is it only one side or are both sides affected? Do the rear lights flash or fail in the same way? Knowing these details will help determine which circuit is involved to help diagnose the issue.
Old Oct 29, 2025 | 10:41 AM
Bruthajoe's Avatar
wow that was thorough. 👍 So the offender is the right running/signal light . The rear lights work regardless of the front condition. Only the r/f will go dim and not flash. This can be also observed when the left signal is activated. And sometimes it will go back to normal. I also see no difference when headlights or fog lights are on. My harnesses are all visually ok. Jiggling harnesses does nothing. But slapping the console on the right side of the radio makes it glitch for sure.
Old Oct 29, 2025 | 10:55 AM
That sounds more like a problem with the DRL module which is mounted to the defroster duct directly behind the radio. It controls the switching of the front lamps between DRL mode and turn signal. There are internal relays which manage that switching. It's possible that the relay for the right side is sticking and failing to engage properly. Unfortunately, the internals of that module are considered "non-serviceable" by GM although the relays can be replaced if you're good with soldering on printed circuit boards.
There are ways to test the DRL module but they are somewhat complex (using a multi-meter - there is no specific tester available) and not always reliable when investigating an intermittent problem. If you really wanted to confirm, you could remove the radio and then tap the DRL module directly when the problem occurs... that would be a good indicator that the module is the problem. Otherwise, I would just go ahead and replace it. The part number is 10407669. It sells for ridiculous prices over $250 at regular parts suppliers, but it's available on ebay for $50-$60 and probably much less at your local junk yard.
Old Oct 30, 2025 | 09:05 AM
Bruthajoe's Avatar
I think you just saved me like 8 hours of troubleshooting.
I'll take em both out and post pics of the repair. What's with the PCB's n these cars ?
