Testing BCM
Old Dec 1, 2025 | 10:55 AM
2000FormulaMan's Avatar
Default Testing BCM
Is there a way to test the BCM BEFORE opening the door panel up to get to the window motor?
Old Dec 2, 2025 | 12:26 PM
WhiteBird00's Avatar
Ungrounded Moderator
That depends on what you want to test. Certainly it is possible to test the inputs and outputs of the BCM using a multimeter or test light. There is (or was) a scanner for testing certain internal functions of the BCM, but it was a dealer-only tool.
What exactly are you trying to test? What are the symptoms that the BCM might be malfunctioning?
