Door speaker replacement question...
1) I haven't dug into the door yet and I'm wondering if I will need a foam baffle to keep water away from the back of the driver:
http://www.partsexpress.com/pe/pshow...60-788&scqty=1
2) Also, will I likely need a MDF spacer?
3) I will be adding damping material as well. Sould I retain the existing plastic water shield or would a complete application of adhesive vinyl damping work in lieu of the water sheild?
Thanks for any response.
Note that the baffles are back ordered at parts express. At any rate, I made a new mdf baffle and added an additional screw for more support. I documented the whole thing here:http://www.anycities.com/user/trplto...omponents.html
I did the write up in excel for ease of editing. Just right click and save target on the word "components" if you want to see a step by step process.
Russell
Did you get your foam baffles installed? I ordered mine through Crutchfield - I saw Partsexpress was on backorder. I'm getting the 6.5" x 3.25" deep ones from Crutchfield. They should be deep enough for my Vifas. I'm wondering though... could you estimate the distance from the speaker mounting surface of the .5" THK MDF baffle to the glass when the window is rolled down? I've heard that the XTC baffles will audibly slap anything in close proximity under high volumes.
Thanks again!
Curtis
I haven't installed the baffles yet as I just got them yesterday. A note though, don't install the complete baffle. Cut it so that it resembles the stock baffle. I.E. cut out the bottom half of the "basket". It's just there for water protection, not to act as an enclosure. You are sound deadening the door right? If so, you will really hurt the sound by installing the XTC baffle in it's entirety as the mid will have a very small airspace to work in.
Hope that helps some. I'll post some pics when I get the baffles installed to show you what I mean.
Russell
Thanks again!
That Vifa is a good choice. Who did you get to design the XO or are you designing it yourself?
Regarding the foam baffle. If installed as is, it will certainly behave like a rigid enclosure. True that it will expand and contract, but only to an extent and the volume of air in the enclosure at maximum expansion is the most air the driver will ever see. Also, with the yo-yo behavior of the foam baffle, you'll see all kinds of strange back waves hitting the driver. It's very important to cut out the back side of the foam baffle. They work okay if you have a small volume driver and don't want to mess with fabbing up an enclosure, but with our doors and an IB driver you are much better off cutting the foam baffle up.
I still haven't got mine installed yet
It's on the list for this evening.Russell
I'll be using an active digital bandpass crossover built into the eclipse 8053 for the Vifa's. They'll each get a channel off a zapco ref 360.
