Steering wheel controls & new head unit
Ls1tech Bad Ass
you do have to splice the PAC switch into the stock wires, but you wouldnt necessarily have to cut them completely; then the infared sensor (looks like a very small LED) sits anywhere on the dash or anywhere in close proximity and thats how it reads the signals from the steering wheel controls to work with your aftermarket head unit.
Ls1tech Bad Ass
not real sure.. why are you so worried about cutting some wires? you can solder the spliced connection and it will conduct just as well as it did before and give a pretty permanent hold if you do it correctly..
how many wires did you have to splice?
Originally Posted by Phoenix57
what do u think most of us on here are doing, were screwing with factory stuff. if ur not comfortable with it, then pay someone to do it.
It stands to reason that since the controls send a signal to the stock head unit, the control line can be taken out of the connector without splicing. Might not be pinned out with the standard aftermarket connector kit, but I gotta think you could stick a pin in the right socket to get at it. Seems to me I read some instruction on that somewhere around here, or maybe another site?
#33
Do you think the IR signals sent out by the PAC unit can be read by an IrDA connector on a computer?
I have a carputer setup and would really like to use the steering wheel controls for seek up/down. Volume already works since the carputer is jsut feeding signal into stock radio.
#35
Originally Posted by InfiniteReality
Anyone have pics of where the eye is mounted for the PAC? I have it all wired, just need a perfect place for the eye. Behind the cup holder is a possiblity, but if a drink is in it then it'll be no good.
#37
Rear one or front one?? That's a VERY good idea!
Lemme know what happens
#39
I rethought it and went to look outside. I think it could actually be run fairly easily in a T-top car, its easy too pull down the headliner along the T-top area. Just use a clothes hanger to fish it back to the light.
