Does anyone else's radio reception suck
Mine has been horriable since day one. I replaced the radio. So now GM naturally says it a problem in the radio. I have just added a booster and that made it even worse. I'm just wondering if everyone has poor reception or If I sould try and replace the antena. I have the stock GM power antena.
Thanks Rob
Thanks Rob
My reception was fine with my stock radio and power antenna. When I switched my head unit, the reception was still great. It could be a faulty antenna, a bad antenna ground, a split in the wire leading from the antenna to the radio, or it might be your location.
Copy & Paste Moderator
This may sound dumb but, make sure the antenna is actually connected properly. I've had the stock Monsoon headunit and antenna replaced under warranty due to failures and they didn't properly reconnect the antenna.
