12 cd changer
Old Oct 4, 2004 | 04:50 PM
HASTINGSRJ's Avatar
Default 12 cd changer
I have a 12 disk cd changer in the trunk of my vert. Does anyone else have problems with them skipping when you hit a bump It is tightened down all the way too. Could it possibly be going bad Any help is greatly appreciated. Thanks
Rob
Old Oct 4, 2004 | 04:57 PM
Xsta Z 28's Avatar
Mine skips. But then again, I have lowering springs, stiffer shocks, so it isn't going to be happy.
Old Oct 4, 2004 | 11:14 PM
howierd42's Avatar
It skipped before I lowered my vert and after. It does not matter how much you tighten it down because it is on a suspension of it's own that really does not work (as you can tell). Some times it skips so bad that I wonder if it is going to start back up again. So now I have elected to pull the monsoon and install a whole new aftermarket setup.
Old Oct 7, 2004 | 02:33 PM
HASTINGSRJ's Avatar
Yeah, I was thinking about going with an in-dash cd player, but I kind of like not having to deal with changing the cd's out all the time.....oh well, guess I will just have to live with it then....thanks for the help guys
Rob
Old Oct 7, 2004 | 03:34 PM
jimmyblue's Avatar
Moderator
The hot tip is probably -not- to bolt it down tight,
but to make an isolation pad for it (to soak up the
abrupt bangs). On my list of neat stuff to try that
I will never get around to. Like, glue 1" of foam
rubber between two plates of {something not too
ugly}, screw down bottom plate to the trunk pan and
top plate to the changer case.
In-dash, a single-CD MP3-playing head unit will hold
about as much music on one data CD as the whole
changer full of audio CDs will, anyway.
