Sound from Comps w/o amp on?
Old Oct 22, 2004 | 12:48 PM
1_BadHawk's Avatar
Default Sound from Comps w/o amp on?
Right now my front comps are connected to my amp which is connected to the head unit via rca cables. The speakers produce no sound until the amp is turned on. Is there a way to change that, so that the speakers operate under normal head unit power without the amp, until the amplifier is turned on? By the way, the amp is turned on/off by a seperate independat switch I installed.
Old Oct 23, 2004 | 08:23 AM
badhoopty's Avatar
i'm no expert, but i suppose you could fab up some kind of wiring harness on the speaker-out side of the amp that you could unplug and connect to the speaker-outs on the deck.
Old Oct 24, 2004 | 08:15 AM
2MuchRiceMakesMeSick's Avatar
There is no 'good' way to do this. Why would you even want to do it? The amp is probably alot cleaner then your head unit. You may also want to wire your amp to the remote turn on (usually the blue wire), I have seen alot of dead batterys because of a 'switch'
