CD player Install
Old Oct 23, 2004 | 12:20 AM
Zdawg_42's Avatar
Default CD player Install
Has anyone or does anyone know how to install a cd player into a 91 silverado with the cassette player/equalizer in the center of the dash? I am having difficulty even finding the wiring harness. If this is not possible, does it work to run a line off the rear speaker wire to the inputs on the amp? Obviously not as good of sound, but possible?
Old Oct 23, 2004 | 11:00 AM
megabass's Avatar
I've done it before. Total pita. You should check to see if metra makes a harness. Pretty sure they do. Then you can use a oem-1 for the amp hook-up.
Old Oct 23, 2004 | 03:27 PM
SilverWS6_2002's Avatar
Its no big deal. 99-3000X dash kit from Metra (X = Color of Dash). 70-1858 Harness. 40-GM10 Antenna Adapter. Go behind the ash tray, you'll locate the tuner pack. It's right there. Piece of cake once you get to it. Metra also makes a pocket so you don't have to leave the sqare radio in the dash. Can't remember the Part #.
Old Oct 24, 2004 | 08:01 AM
2MuchRiceMakesMeSick's Avatar
A 91 chevy is about the easiest install there is. Just get the metra kit and the wireing harness
