Factory Alarm Problems
Old Nov 10, 2004 | 01:33 AM
SApache40's Avatar
Default Factory Alarm Problems
When I lock my car it honks twice like usual, but 10 seconds later the alarm goes off on its own. I push the red button with the horn to make it stop. A couple hours later it goes off again. It started doing this a couple days ago. Anybody know what can be the problem?
Old Nov 10, 2004 | 08:54 AM
lnuxhakr's Avatar
sounds like the sensitivity is set too high
Old Nov 10, 2004 | 11:23 AM
WhiteBird00's Avatar
Ungrounded Moderator
The factory shock sensors are known for failing and causing the symptoms you describe. Try programming the system to disable the shock sensor and see if you still have the problem.
Old Nov 10, 2004 | 08:52 PM
SApache40's Avatar
I disconnected the shock sensor and locked the car. Alarm didnt go off in seconds like usual. So I reconnected the shock sensor to make sure that was the problem. Locked the car again and alarm didnt go off again. Alarm seems to be fine now, didnt go off at all today. Wonder what happen, maybe it got reset when I disconnected it.
Old Nov 17, 2004 | 07:47 PM
69_YENKO's Avatar
My car alarm has been doing the same thing it started about 4 hours ago, i armed it after getting home from work & just as described above it went off about 10 sec later. you say the shock sensors, where are they located? Ive never messed with the alarm before, how do you program it?
Old Nov 17, 2004 | 07:48 PM
69_YENKO's Avatar
does it seem like the problem has been fixed after unhooking the unit?
Old Nov 17, 2004 | 08:39 PM
Nova5's Avatar
shocks ensor can be found over the rear right wheel well. inside the spare tire compartment. the grey **** adjusts its senstivity.
its likley his connections were dirty and causing signal abberations. disconneting and reconnecting scraped some gunk off the contacts is all.
Old Nov 17, 2004 | 08:58 PM
69_YENKO's Avatar
thanks, i'll give thatr a try. i didnt even know where the thing was located
