where to ground my amps at?
Old Dec 8, 2004 | 02:38 AM
scifone's Avatar
Default where to ground my amps at?
i need a good place to ground my amps in my camaro... i searched and found nothing. i looked around the trunk briefly and didnt find a good place to ground them. any info on where you guys used would be awesome. thanks in advance.
robby
Old Dec 8, 2004 | 05:27 AM
Gb0dy's Avatar
pull your seats out and ground it where the seat bolts down. Make a good connection by grinding down the paint around the area before you screw the bolt down. Take your time the amp will function the best when it has a good grouns.
-gary
Old Dec 8, 2004 | 06:24 AM
CamTom12's Avatar
I grounded mine to my power antenna... I think that's where the Monsoon amp grounds, too.
Old Dec 10, 2004 | 05:32 PM
ls1rocker's Avatar
i grounded mine back by the hatch lock, there is a triangular strip of metal that is support for the lock i believe.
its right under the latch, just pull back the carpet
Old Dec 11, 2004 | 02:27 PM
96redformula's Avatar
the seat belt bolt it always a good spot..
Old Dec 14, 2004 | 03:13 PM
Prophecy's Avatar
yea i used the seatbelt bolt to dround mine, make sure u sand the paint to bare metal...
Old Dec 16, 2004 | 03:56 AM
transambandit's Avatar
when i pulled out my cd changer i stuck a bolt through where it bolted up and stuck a nut on the end, worked pretty good.
Old Dec 16, 2004 | 11:54 AM
Nate_Taufer's Avatar
yup theres plenty of places in the rear cargo area. just pull up the carpet and look around. grind a little paint away and you're in business. I also used the old cd changer spot.
Old Dec 16, 2004 | 01:38 PM
tuffluck's Avatar
this can be an excellent spot! two recommendations:
1. use really beefy ground connectors. i'll explain why in #2.
2. if you've pulled out your monsoon amp, take one of the screws holding the monsoon amp in it's place, and use that instead of the screw found in the triangular piece. there are 2 grounds on the triangular piece already. move the one that won't fit on the monsoon amp screw to the bolt directly beside it. use the monsoon screw and tighten the hell out of those grounds. do make sure to sand the paint down as well. the stock screw found in that triangular piece will strip and will not get tight enough for a good ground connection. using the monsoon screw will widen the hole, but leave a very tight connection.
