lights flickering
Old Dec 10, 2004 | 11:18 PM
00ws6blackbird's Avatar
Default lights flickering
I dont know if this is in the right forum but my buddy has a 2000 formula and his headlights and taillights are always flickering. They will be alright one second and then start to dim all the sudden. Any suggestions will be welcome....Thanks
Old Dec 11, 2004 | 12:45 AM
SUX2BU's Avatar
Sounds like the alternator. swap it out with a good one to see if it goes away. shouldn't take but 30 min.
Old Dec 11, 2004 | 03:04 AM
badjuju342's Avatar
Deranged Rat Fink
Alternator , loose headlight grounds or loose connection, check the alt first then the headlights. If it's just the headlights and nothing else acts strange , I would check the grounds , A loose ground would just precisely what you descibe because it makes a ok contact to the the chassis and then doesn't as the car moves /hits bumps.
Old Dec 12, 2004 | 11:00 PM
BIG RED's Avatar
if hes got a system in his car it could be drawing to much power when the bass hits. there is a quick, easy, and relitively inexpensive solution to the problem buy a 2 FARD capacitor for it
i had that problem till i got an audiobahn 2 FARD CAP ............then no more dimming for me
Old Dec 12, 2004 | 11:27 PM
He does have a system in his car but the lights flicker all the time....even when the stereo is turned off.
