Remote Start???
Old Dec 16, 2004 | 07:12 PM
CAMMIN03''s Avatar
Default Remote Start???
Guys how hard is it to install a remote start system..... i know i need the bypass module... everywhere i have called just for the install they told me between 250-500..... is it really that hard???
Old Dec 16, 2004 | 07:56 PM
tonyt123blue's Avatar
depends on how much you know about wiring.could you put a whole new system in your car?amps speakers everything like that.if so give it a try.if you cant find your fuse box better pay to have it done.you can always ry and bargain with shops.
Old Dec 16, 2004 | 08:18 PM
jimmy 2 Times's Avatar
does you key have a little resistor chip?? if no then it is easy, pm if you have any questions
Old Dec 17, 2004 | 12:40 AM
z28smokin's Avatar
I just purchased a complete viper remote start system from best buy for $205 installed. This was for my 97 Jimmy.
Old Dec 17, 2004 | 06:33 AM
there you go its not worth doing yourself for that price.let them get dirty
Old Dec 17, 2004 | 10:12 AM
BoonesZ's Avatar
just buy the honda2000 kit
Old Dec 18, 2004 | 04:29 PM
SSactionLs1's Avatar
its easy if you know what you're doing. You DO NOT NEED A BYPASS.. take a DMM to your key and measure the resistance, then go get a resistor that matches and wire it to the small yellow wire in the colum. It will take you a good 4-6hrs if you arent experienced.
Oh you will need the 456G if you want power locks, parking lights, door trigger.etc.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red (x2) |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink (12 awg) |+ |ignition harness |
| SECOND IGNITION|white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|use Directed module | | |
| POWER UNLOCK|part #456G *2 | | |
| LOCK MOTOR|gray | |driver door module in door |
| UNLOCK MOTOR|tan | |driver door module in door |
| DISARM DEFEAT|tan | |pass. door module in door |
| PARKING LIGHTS +| | | |
| PARKING LIGHTS -|gray/black | |brown plug @ BCM *1 |
| HEADLIGHTS| | | |
| DOOR TRIGGER|gry/blk(L),blk/wht(R|- |each door module in door *3 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN| | | |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|lt. green |- |driver door module in door |
| TACHOMETER|NOT pnk, blk, or brn| |any ignition coil |
| SPEED SENSE| | | |
| BRAKE WIRE|white |+ |brake pedal switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|pink |- |steering column |
| LF WINDOW UP/DN|blue - brown |A |driver window motor |
| RF WINDOW UP/DN|blue - brown |A |passenger window motor |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE| | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V| | | |
| RADIO GROUND| | | |
| RADIO SWITCH| | | |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA| | | |
| LF SPEAKER| | | |
| RF SPEAKER| | | |
| LR SPEAKER| | | |
| RR SPEAKER| | | |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. The passlock II wire colors are yellow, black, and red/white (not used). *1 The BCM (Body Control Module) is under the driver side dash. *2 If Directed module part #456G is not available, refer to directfax document #1601. On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM. *3 On base model trucks the door trigger wires are in the lt. blue plug at the BCM. On 4dr trucks the LR door trigger is lt. blue/black, and the RR is lt. green/black. They are in the purple plug at the BCM. Use all wires and diode isolate.
Old Dec 19, 2004 | 11:08 AM
shouldaboughttheZ's Avatar
I am also looking for some help in this area. I have the DEI 551T and the Universal Alarm Bypass Module #20401. I have not hooked up an alarm in years. I used to be big in the car audio scene, and could probably do it back then. Is there someone locally you might want to help out, or maybe someone could help me walk through it. I see your post with all the wiring colors, is that going to be the same on my car?
I just want to add it to the factory set up.
Old Dec 19, 2004 | 12:51 PM
get rid of your alarm bypasss module and measure your key resistance instead. its 15 cents vs 49.99....
I am not familiar with the 551T, but ill go check that out.
Chevrolet Camaro Security Information
Constant 12V+ Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 Brown Ignition Switch Harness
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White Rear of Engine on Wheel Housing (PCM)
Neutral Safety Wire Orange/Black (-) Switch Base of Gear Shift
Brake Switch Light Blue Brake Switch
Trunk Release Black/White (+) Switch or Brown at Blue Connector on BCM
Trunk Pin Orange/Black (-) BCM Blue Connector Passenger's Kick Panel
Parking Lights Brown (+) Head Light Switch or Blue Connector BCM
Head Lamp Yellow (+) Light Switch
Door Trigger Gray/Black (-)DR Black/White Passenger's Blue Connector at BCM
Door Lock Red/Black (-) BCM Passenger's Kick
Door Unlock Orange/Black (-)
Driver's Lock Gray (+) Motor
Driver's Unlock Tan (+) Motor
Horn Wire Black (-) Steering Column or BCM
Windows Up LF=Blue, RF=Blue
Windows Down LF=Brown, RF=Tan
Old Dec 19, 2004 | 04:43 PM
Thanks for the info. Now since I am using the passsenger unlock option to activate the remote start. Which wire on your layout do I cut?
Old Dec 19, 2004 | 05:11 PM
red/blk
orang/blk
in pass kick
Old Dec 19, 2004 | 08:06 PM
WhiteBird00's Avatar
Ungrounded Moderator
Be sure to add an ignition controlled relay - otherwise the starter will run any time someone pushes the unlock button on the passenger's door (a side effect of using the progressive lock mod). Adding a relay prevents that from happening when the engine is running.
Old Dec 20, 2004 | 03:52 PM
Originally Posted by SSactionLs1
red/blk
orang/blk
in pass kick
You state two wires here. I was under the assumption that I had to only cut one and tap it into the other one.
Old Dec 21, 2004 | 05:33 AM
2MuchRiceMakesMeSick's Avatar
Its not really that hard. Just takes time. I was an installer for several years though
Old Dec 21, 2004 | 10:24 AM
To bad you are in the Dallas area, you could come down and help me...lol.
