quick electrical question for fog lights
and there is a red wire and a white wire for my halo headlight.
which do i hook up to which?
thanks in advance.
Red is typically +12 (switched, if I remember correctly) and Black is typically Ground. I'd try connecting the Red halo wire to the Purple fog light wire and the White halo wire to the Black fog light wire.
I did a quick search and found some threads that discussed wiring, but nothing about fog light wiring colors. Here are a couple links on alternative wiring methods:
https://ls1tech.com/forums/showthrea...ht=halo+wiring
