New components installed today, sounds like A$$!
Old Jan 23, 2002 | 09:10 PM
Quickin's Avatar
Default New components installed today, sounds like A$$!
I just had MMats speakers for the doors and back seats, an Audiobahn AW1200X 12" sub in a stealth box and a Planet Audio 6005 amp installed.
Sounds INCREDIBLE when it's cranking. But down low it has all kinds of hissing, engine noise and popping in the coax's.
I kept my Monsoon Head unit, is there any way to get rid of these noises and keep the factory head unit?
Do the steering wheel controls still work with an aftermarket HU?
Thanks!
Old Jan 23, 2002 | 10:28 PM
Blistering Z's Avatar
Default Re: New components installed today, sounds like A$$!
Sounds like it could be a bad ground or something. Sometimes speaker and RCA cables can pick up interference from the power wire. Are they run down the same side of the car?
Dan
Old Jan 23, 2002 | 10:40 PM
BraemerZ28's Avatar
Try separating the RCA's and power/ground wires like was suggested above.
Since you are using the stock head unit (no RCA outputs as far as I know), I'm guessing that your amp has speaker level inputs? Or are you using high-low level line converters to get the signal into the amp? If you're using line converters, you'll get more hiss no matter what. You can try higher quality converter units if you want which may help some.
The other thing you can try is to check the gain settings on your amp and above mentioned line converters if you have them. If you have the gain cranked all the way up on one or both of these, you can get some hiss at low volumes. Back the gain off to about 3/4 and adjust your head unit volume accordingly to see what happens.
With the gain all the way up, it's kind of like turning your TV volume all the way up when a DVD or tape is on pause. There is no sound comming out, but the amp is stil trying to put out a bunch of power with no place to go.
If none of this satisfies you, you may be headed for a new head unit.
Forgot to mention... these ideas may take care of the hiss. The popping and engine noise is more than likly a ground problem. If you have line level converters, they are a great place for ground interference problems. Also check where you have your amp ground wire connected. Make sure it is far away from anything electrical - tail lights, dome lights, door switches, power antenna, etc.
The wheel controls can be made to work, but last I checked, it's expensive.
Later,
[ January 23, 2002: Message edited by: BraemerZ28 ]</p>
Old Jan 23, 2002 | 11:07 PM
Quickin's Avatar
Thanks allot, I'll take these posts back to them tomorrow and hopefully they will take care of it.
Old Jan 24, 2002 | 10:08 AM
Bad30th's Avatar
Couple of things :
1) It's cheap to make your steering wheel controls work with any IR compatible aftermarket head unit. I have one of these I use with my Eclipse 54420 :
http://store.clubgp.com/catview.asp?catid=6
PAC SWI-X
2) Definately run the speaker wires on one side of the car and power/ground on the other. Makes a big difference in RF noise. Also the converters will cause a little noise. Get an aftermarket head unit to realize the full potential of your new setup - your ears will thank you because the stock head unit is a turd in disguise.
Happy driving,
BadAss30th
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Old Jan 24, 2002 | 01:49 PM
Quickin's Avatar
Well, I was starting to believe I might need a new HU.
I was driving this morning, hit a sharp bump and ALL the undesirable noise went away 100%. I mean everything. It's crystal clear now.
But, when I start up for the first time the crap comes back for about a minute then goes away for good, until I shutdown again.
So what the heck is loose?
Thanks
Old Jan 13, 2005 | 03:43 PM
LS1_Unleashed's Avatar
I'm not an audio genius by any means, but I was told by a local audio shop that certain wires that run from the amp to the other speakers and etc. can pick up engine noise and will tap into other electronics in the car and make a buzzing sound. What everyone else posted is correct. From what I have heard, you should get a nice set of cables, and maybe a new head unit. But try the top of the line cables and if it is still making that sound ask an audio shop about it.
Old Jan 13, 2005 | 08:27 PM
Danny2tek's Avatar
wow somebody brought this back from the dead
Old Jan 13, 2005 | 08:33 PM
VIP1's Avatar
Copy & Paste Moderator
I hope this guy isnt still having this problem 2 years later.
Old Jan 13, 2005 | 08:54 PM
Danny2tek's Avatar
Try almost three years
Old Jan 15, 2005 | 01:12 AM
VIP1's Avatar
Yeah, my math is a bit off.
I guess I forgot that we are in 2005 now.
Old Jan 15, 2005 | 05:18 AM
SSactionLs1's Avatar
wtf lol
well ****..what was the prob lol
