CD Changer Installation (ignition)
Old Jan 29, 2005 | 02:28 PM
Rescue Ranger's Avatar
Default CD Changer Installation (ignition)
Hey everyone
I recently purchased a Sony MP3 cd-changer, and there are 3 wires to hook up for power. One (yellow) is battery, black is obviously ground, and the red is ignition lead. Where can I install this red wire? I know on an aftermarket headunit, i could use the preamp (usually blue) but I currently have stock monsoon system.
Thanks in advance
Old Jan 29, 2005 | 04:02 PM
Bump!
Old Jan 29, 2005 | 04:15 PM
skewba98z28's Avatar
Been trying to research it with not many answer's. But what most people are saying is pull your headunit out and in the 20pin harness there is a spot that is unused and one of them is a remote wire. The reason there is one that is unused is because the Birds have power antenna's and camaro's don't. So just take a test light or a voltage meter. and try the pins out on the back of the headunit. Just stick the test light in the empty slot's and turn your key on and off and see if you light comes on and off. I also found that there is a pink wire coming out of the steering column that is a ingnition wire. I would probably try the radio first though.
Old Jan 29, 2005 | 04:17 PM
hmm that sounds like something I can work with, thanks man. I remember in my honda before I had an aftermarket HU i hooked into the fuse box, but ideally i'd like to hook into the remote lead.
Old Jan 29, 2005 | 04:19 PM
Yeah I don't blame you there. Oh yeah BTW Welcome to the winning team.
Old Jan 29, 2005 | 04:21 PM
lol thanks. i actually had a mustang gt before i got the camaro, (hated the stang) but my civic is my loyal daily driver
Old Jan 29, 2005 | 04:22 PM
anyone else have a suggestion for ignition remote lead?
Old Jan 30, 2005 | 07:34 PM
WhiteBird00's Avatar
Ungrounded Moderator
In the fuse box there are three extra connectors - one for battery, one for ignition, and one for accessory (same as ignition but also powered during "retained accessory power" operation). It's fairly easy to tap into any of those and route your wiring through the dash or wherever you need it.
Also, why would you need the remote turn-on lead? Why not just tap into the radio power? That would be the yellow wire in the black 10-pin connector on the back of the radio.
Old Feb 3, 2005 | 12:26 PM
BJM's Avatar
BJM
Are you planning on hooking it up to the stock head unit? If so, I was wondering how, I have a SOny CD changer I want to use as well with my Monsoon
Old Feb 3, 2005 | 12:33 PM
There is no way to hook up a Sony CD changer so that it is controlled by the factory radio. The only aftermarket changer that will work with the factory radio is the NeoChanger which is specially designed to do that. Alpine and Kenwood used to make adapters to connect their changers to GM radios but they're not available anymore.
You can hook up your Sony through an FM modulator but you'll have to use the controller that came with the changer to switch tracks or discs and the sound isn't as good as with a direct connection.
Old Feb 3, 2005 | 01:49 PM
BJM's Avatar
BJM
I thought that was the case, I was just hoping someone had discovered something new.
