all lights flickering
Old Feb 4, 2005 | 12:44 AM
99camaroB4C's Avatar
Default all lights flickering
Heres the deal. Whenever I start my car all lights, interior and exterior, flicker. They flicker faster when I rev the motor. The flickering usually stops about 10 or 15 minutes, but sometimes it just keeps on going. Is it the alternator? or something else
Old Feb 4, 2005 | 12:48 AM
Richiec77's Avatar
Sounds like a bad ground that might be loose. But it is probably you regulator in the alternator. Get a mulimeter and get some reading of your voltage out put. An older style analog voltmeter is perfect for this. The needle is very responsive to surges and slight changes in voltage and can "sense" fluctuations better. That is why they are still produced and usefull.
Old Feb 4, 2005 | 03:51 PM
baddogz28's Avatar
Mine was doing the exact same thing... Replaced the alternator and "Voila!" Problem solved!
Old Feb 4, 2005 | 04:22 PM
BigBadWolf's Avatar
Same here.. gotta look into a new alternator as well.
Old Feb 4, 2005 | 07:39 PM
LS69TA's Avatar
Mine is doing it as well. The lights are flickering some at night and the needle on the gauge is jumping around. I have a new Optima red top I'm going to put on, and I have a alt. on my 02 LS1 that I may pull off to see if that fixes it. From searching the posts, it seems like the regulator in the alt. is acting up.
Old Feb 4, 2005 | 07:49 PM
Richiec77's Avatar
Yep. Looked a little closer and that is definetly a MAJOR symptom that you need to replace the alterantor. Our's are internally regulated so you have to replace the whole unit.
Old Feb 5, 2005 | 01:16 AM
Thanks for the help guys, it is appreciated.
Old Feb 5, 2005 | 10:11 AM
01ArcticSS's Avatar
Default Alterntor & Connector
I had mine replaced a couple of weeks ago too - same problem - the service rep said something about a connector causing the alternator problem and they replaced that too - there might be a TSB on this?
Todd
Old Feb 5, 2005 | 12:30 PM
Richiec77's Avatar
Did he say something like a terminal??
Old Feb 5, 2005 | 07:04 PM
01ArcticSS's Avatar
No, not that I recall...something about a connector - he said something about "field" something or other, too - can't recall exactly....sorry
Todd
