Audio Help
Old Feb 6, 2005 | 12:13 AM
camaro 28's Avatar
Default Audio Help
Im using the stock head unit (monsoon) and i went to columbus car audio and accessories to get an adapter for speaker to RCA, and i dont have directions. Has anyone ever done this? If so, can tell me how to hook it up? BTW, i have a 00 chevy camaro
THANKS
Old Feb 7, 2005 | 12:56 PM
sexyvic1's Avatar
post pics of the adapter u bought.
Old Feb 8, 2005 | 01:06 AM
Richiec77's Avatar
Are you talking about a Generic High to Low converter? (speaker level input. 2 gain controls and then 2 RCA outputs)
Old Feb 8, 2005 | 05:36 AM
My-bird99's Avatar
all your doing is converting the factory speaker wire into a RCA signal. I assume you are installing an amp to power some subwoofers in the back.All you have to do is splice into the rear speaker wire connect it to the (in line converter) thats the actual name for the part you bought,and then plug the RCA cables from there to the amp.The converter should have four wires coming out of it on one side and female ports to plug the RCA cables on the other.pretty self explanatory positive-negative to positive-negative. when you splice off the speakers though make sure you still have wire going to them so either solder the wire or cut it a ways down.A in line converter is a good way to add a sub fill without spending a lot of money but i do recommend upgrading your system if your looking for a better sound.
Hope this helps...
Old Feb 8, 2005 | 02:02 PM
Richiec77's Avatar
My-bird99 is right. All you are going to do is to go
LR= Left Rear RR= Right Rear
speaker//////////////////////////Converter
LR + ------------------------- + Left
LR - ------------------------- - Left
RR + -------------------------- + Right
RR - -------------------------- - Right
Old Feb 9, 2005 | 02:21 AM
Richiec77's Avatar
Also you can find quick connect Splices. They basically snap on over the wire and you don't have to cut and splice.
They look like the set on the bottom part of the pic.
http://multimedia.mmm.com/mws/mediaw...vvv&0NGyVVVVU-
http://products3.3m.com/catalog/us/e...er/output_html
You can get them at most auto stores. Something like $2-4 dollars for a set.
3M. Got to love that company.
