probably a noob question but..
I used to think the same thing. The larger Sine wave (low Freq.) is more like DC than the higher freq. It is not. RMS is an average measurement of output. Now intersecting wave points will increase current draw and the subs lower resistance will dictate that it will want the power more, but on an average the statement I 1st posted is correct. (I had a slightly long talk about it with Mark Eldridge) So all that means is that under NORMAL use the splitting is mostly correct. Under SPL type use. The Sub will dictate the most current.
From the amp + --[====]------[====]-----[====]-----[====]------[====]-- Speaker+
5 10watt 1.0ohm resistors wired in series. Just make sure they are well protected. and don't short on each other. If you can solder, Perfect. If not, get some butt splice crimps.
Go to a Auto Parts Store or radio shack. Get the red colored ones. (20ga to 18ga) They look like little barrels.
I knew this was gonna happen. No big deal i guess. I hate butt-connectors and I've never soldered before.....looks like its time to learn. Anyway, I was trying to get things set up and ready to go and I was wondering what size wire I should use to wire the sub? I was thinking 12 gauge.
Just use 12ga speaker wire.
