Cigarette Lighter not working
14 Second Truck Club
Okay, my cigarette lighter is not working. My 12v accesory port righ by it is working. There is no burned fuses, but they should be on the same fuse anyway. I removed the panel and checked the plug going to it and there is no voltage there. Any ideas? They both have orange and black wires going to them and I tried to trace the wires back to see where they went, but I dont not want to tear apart the console and dash to fix it, I may just splice a jumper between the 2. I am not sure when it stopped working or if I ever even tried it before. It is an 04 silverado.
If there isnt any voltage comming from the orange wire than eitherr there is a blown fuse some where (did you check under the hood? there are like three acc. fuses) or something is disconected/cut (check under dash)
I wouldnt suggest splicing the wires, if you ever need both outlets you might have a problem with the fuse holding up
