I just bought a AAI-GM9 for my ipod and having issues
I'm trying to plug it all up and get it to work. I have a 2000 Camaro that did not come with the factory cd changer. What do I need to do in order for this to work correctly. I currently can not switch AUX because there was never another aux device in my setup. Any help is appreciated.
If the head unit needs a signal to switch on to aux, which wire is it the supplies this signal, could I need just supply a switch that sends the same power to get it to activate?
Ungrounded Moderator
The AAI-GM9 will not work unless you have the "slave unit" attached and operating. This means you need to have the external CD changer installed for the adapter to work. PAC's website says:
Requirements: The sedan or SUV/truck factory headunit must have a separate working slave unit which uses the GM 9 pin connector (1995-2002 vehicles). Slave unit examples are: external CD changer, cassette player and/or single CD player. Please note that the slave unit must continuously be playing for the AAI-GM9 to work.
The single CD player they refer to is not the one in the head unit - it's an external accessory that was available for some GM cars to add CD capability to cassette head units.
You should take that adapter back and get yourself the iPod2Car adapter which doesn't require the external changer in order to work. (In fact, it requires the changer be disconnected if you have one.)
The 9-pin connector for the CD changer has a drain wire, left and right audio signal, common audio return, power and ground wires. I'm not familiar with how the head unit determines if the changer is present using those wires and internal schematics aren't available to me. I doubt a constant 12V signal will work because the external changer receives power from the head unit through the 9-pin port on the back - not the other way around.
The iPod2Car interface is expensive but it enables control of the iPod using the head unit buttons. If all you want is an auxiliary input adapter, go with the GM9-AUX from PIE. It converts the head unit changer port into auxiliary input without requiring the changer be installed and is available for under $70 (I've seen it as low as $59.99).
Thanks man, I'll see if I can find the PIE and get that work.
This is what I need?
http://shop.store.yahoo.com/csexpo/gmpieauinco.html
