kinda new to this, sub and amp questions inside
Old Mar 9, 2005 | 10:01 PM
WS6FirebirdTA00's Avatar
Default kinda new to this, sub and amp questions inside
ok so i was thinking about maybe getting a sub for my trunk. i would like to make it where i can mount the amp on the box so it is hidden and can all be easily removed. now here are the questions, what all do i need? i helped a friend on his s10 so i have some idea. i know i need the bi gage wire for the battery, that goes to the amp right? then the big gage ground to the body. and then i run wires to the sub itself. how do i go about hooking into the stock unit? something called rca's if i recall correctly. i would think a 10 would suit me well, and from what i have heard from others and actually heard a w3 is pretty good. say i run that and an amp, which i dont need a big amp for that, how much would it all run me? i would think i could get some of this used off here but i would prob want a new speaker, and amp if they dont cost much
what do you guys recommend i do and can you give me a cost?? how do you get the box to stay put in that little opening in the trunk on the driver side? and how can i run all the wire so it is not noticed?? thanks in advance
o yeah and do i have to do anything with any of the stock pieces??
Old Mar 9, 2005 | 11:31 PM
anyone?
Old Mar 10, 2005 | 01:42 AM
2MuchRiceMakesMeSick's Avatar
Might look into JL Stealth boxes. They are relatively light considering normal weights. They fit good and sound good.
Old Mar 10, 2005 | 08:48 AM
do they have this stuff on a web site or could i go to an audio section of an electronics store and look at some of this?
Old Mar 10, 2005 | 12:50 PM
http://www.jlaudio.com/stealthbox/firebird.html
Old Mar 10, 2005 | 06:24 PM
If the vehicle is equipped with the Bose® or Monsoon® subwoofer system, you must purchase a new driver side rear trim panel from GM parts in order to install the Stealthbox®.
i dont really get this that i read on there. and is there room for an amp to be mounted on there? id like to have it where i can take it all out if i go to the strip and i dont wanna go drilling things if you knwo what i mean. and im still lookin for a price on all that, is there a price list on that site or no? and what kinda amp do you recommend, i dont wanna spend a whole lot on this
are there plugs in the back for rca's or do i have to tap into wires? on the stock unit
Old Mar 10, 2005 | 07:16 PM
clemsondave's Avatar
www.subthump.com Same thing, but less $. I have one and it fits perfectly.
Old Mar 10, 2005 | 07:55 PM
ok thanks, keep it commin guys, let me know what i gotta do for this lol
Old Mar 10, 2005 | 08:11 PM
o yeah and where can i run the power wire through the fire wall
and i wanna find a good place to mount the amp where i wont go messing anything else up i would like it to be on the box but from these pics it doesnt look like it can be on the box.
any ideas where to get a good amp thats cheap? i dont need the best just something to push a w3 or somethign equal to sound good. thanks
Old Mar 13, 2005 | 02:38 AM
Do you have the monsoon? Reason for this is because the amp is located there.
No you do not have preamp (RCA) outputs on the back of your factory deck. You will need to get a aftermarket head unit or a high to low level preamp converter.
Old Mar 13, 2005 | 10:08 AM
yeah i do i have monsoon, what is this preamp converter?
Old Mar 13, 2005 | 06:14 PM
Snootch's Avatar
This thread may help you: https://ls1tech.com/forums/showthrea...nd+suggestions
Old Mar 13, 2005 | 07:23 PM
Originally Posted by Snootch
Thanks
PAC makes a 4 channel line converter. A quick search on googlel should give you what you need
Old Mar 21, 2005 | 07:20 PM
HOSS's Avatar
mike, i can run that power cord for you, i ran mine through the firewall below the cars computer, just have to get it through the rubber grommet there, i ran my wires down the passenger side, and then went inder the carpet behind the backseat, u have seen mine, can't see ****
Old Mar 21, 2005 | 07:31 PM
yeah i wanted to look at your car and i posted this when u were out of town lol
Old Mar 21, 2005 | 09:30 PM
Zymosis's Avatar
Originally Posted by 2MuchRiceMakesMeSick
Positives of that box are that you can use the t-top holders and maintain trunk space. However I think with the sub there it would rattle the hell out of the plastic piece above it. And our F-Body's don't need any more annoying rattles.
Old Mar 21, 2005 | 09:32 PM
HOSS has that box and it doesnt rattle one bit from what i coudl tell
Old Mar 21, 2005 | 10:36 PM
HOSS's Avatar
yep..no rattles for me
