some questions
Old Mar 15, 2005 | 08:32 PM
02_2500avalanche's Avatar
Default some questions
Alright audio gurus I got some questions for you guys. First off, I just put 4 6.5" boston acustics speakers in my truck and it sounds very clean which is just what I was looking for cause I listen to a lot of rock. I am looking to upgrade my head unit (I have stock now) to get some more power to those speaker cause I know they would be much better with a good HU. Any suggestions for some good one? I wanna keep it in the $250 range. Now its my moms b-day and I wanna get her a head unit for her 1996 caddy deville. I don't know if its a double din or not, it sure looks it cause the stock HU is huge. My friend has a clarion HU out of a 1996 impala SS and it is a double din and I was planning on buying it for the caddy. Thanks for your help.
Alex
Old Mar 16, 2005 | 02:29 AM
2MuchRiceMakesMeSick's Avatar
Your wanting more power or an aftermarket head unit?
If your wanting to give them the power they need. I recommend some filters, high to low level converter (pac makes a good one) and a good 4 channel amp (rockford fosgate comes to mind)
A head unit will not produce what they say they will. When you see a HU that says it will put out 70x4 (280 watts). Ask your self, how big is a real 280w amp and look at the size of the HU.
Panasonic has been putting tri-path chips which are the most in terms of watts so far for a HU. That maybe an option worth looking into for you.
Old Mar 16, 2005 | 12:11 PM
sexyvic1's Avatar
get your self a nice pioneer headunit, make sure it has 3 sets of rca outputs. and then when u save up more money pick up a nice 4 channel amp.
also if u get that HU later if u decide to add a sub u will be fine withnothing more than a sub amp to buy.
as for what 2muchricemakesmesick said : he is right with the headunits saying like 50w x 4 that is rated max power, RMS u are getting like 15-20watts per channel, but it still does not compare to the sound of if u bought like a 25watt per channel fosgate or what ever good name amp.
