Installation quality
Thanks,
Chris
https://ls1tech.com/forums/wiring-stereo-electronics/301019-questions-about-todays-remote-start-systems.html
On every car I twist the 10ga wire pairs together and tape main wires to look factory. Rule is all soider and tape every time. but on alarms tape all wires and hind or you just labeled all the start and power wires for the bad guy.
All wires should come of a group. Meaning bench prep the system and run gnd and light (twisted pair) the main wires toughter so when work is needed or panel removed it is clean and easy to work around, NOT a ball of extra wire.
I have had dealerships that realy never new a alarm/start was even on the car when they worked on the underdash electrics.
What do you folks think?
Would most places also install extra accessories after the install has been in for a few years or are the accesories something that has to be installed at the same time as the alarm?
Once again,
Thanks.
Amen brutha! Looks like I got a new drinkin buddy!!!
to you too!! Yes but you never REALY know what you are going to get. There are some shops that use special wire splice " just wrap one wire around the other tape and ziptie" that is a NONO
The python and viper 2way LCD's are $200 at cost. If any of you guys are in the Michigan area Duke's Car Audio is rated best shop in the U.S. so check them out. If you are if you are local let me know I have many friends that own shops. That can do great installs. And I could point to where you could get this stuff cheaper
The type of install Daley described is the best type. And I can Vouch for 2FAST4U credentials. That is the Quitesential instal and definitly worth every penny.
I totally agree cause one of the things an alarm can do is make your car immobile. It could be the difference your car starting or you being stranded
