radio question
Old Apr 9, 2005 | 01:59 AM
zrated's Avatar
Default radio question
I am wiring up my nitrous kit and for the arming switch i want to tap into the radio hot wire because, I know this is a ign 12v source is this a good idea and what color is the wire.?
Old Apr 9, 2005 | 06:09 AM
BigBadWolf's Avatar
Don't do it! Anything extra you hook to your stereo is just another opportunity to introduce interference thus creating noise.
Old Apr 9, 2005 | 02:29 PM
zrated's Avatar
Where can I find a 12v ign source to hook my activation switch too???
Old Apr 9, 2005 | 03:44 PM
Nova5's Avatar
pop off your fuse box panel, locate on the map the SINGLE blade connection (not a fuse location - 2 blade) labeld "ACC" this is a Ignition switched Accessory 12v source. just get a flat blade crimp on connector from radio shack or anyplace that has that small part. crimp to wire and stick it in there. I have my hidden power socket hooked up there. useful for devices i want to turn on and off with ignition... Radar Detector... No power, no beep. Cop no hear/see, less chance of ticket!
There is enough space to run the wire up around the edge of the fusebox behind the panel, just need to take off the drivers side knee panel. then bend the back of the crimp connector down a bit.
Also that connection is not affected by RAP (Retained Accessory Power)
Old Apr 9, 2005 | 06:48 PM
WhiteBird00's Avatar
Ungrounded Moderator
Actually, the one labeled ACCY does have retained accessory power. The one labeled IGN is only live when the key is on. (There's also one labeled BATT that is hot all the time.)
Old Apr 10, 2005 | 12:54 AM
Nova5's Avatar
does it? huh.... guess i never really paid much attention to the detector after i shut the car off.
