Alpine Type S or R
Old Apr 12, 2005 | 11:26 PM
1FASTZ28's Avatar
Default Alpine Type S or R
I am thinking about replacing my stock speakers with these throughout the car for now because mine are almost all blown, which one would you recomend and do you think they will be good in all locations of the monsoon system. Also do you think I could get some 5x7's to fit in the rear of the car. Any help would be appreciated, Thanks
Old Apr 13, 2005 | 12:09 PM
88GTA's Avatar
I have the type-r 6.5in components up front and the type-r 6.5in coax's in the sail panel and I think they sound great. I listened to the type-s in the the store and I really didn't like them too much...
Are you planning to keep then stock monsson amp? I don't think it is good enought to power the type-r's. I bought an 80w per channel amp, and just kept the gain turned down a bit since the speakers can only handle 70w and 50w repectively. I don't have anything in the rear (except my 2 10's in the trunk), I don't think you really need any thing back there. Good luck!
Old Apr 13, 2005 | 02:06 PM
2MuchRiceMakesMeSick's Avatar
I think the Rs are the better of the two lines. Dont care for them too much, better brands for the price. Just my opinion.
Old Apr 13, 2005 | 03:12 PM
88GTA's Avatar
you dissing me, yo?
heh heh, j/k.
also, who pays retail?
Old Apr 13, 2005 | 04:19 PM
LoudmouthLT1's Avatar
Alpine makes good amps, subs and head units but there speakers aren't so great. If you insist on getting them get the type R. I'd personally go with MB Quart, Infinity Perfects, Canton or Focal.
Old Apr 14, 2005 | 09:02 AM
PewterNHRA2001's Avatar
infinity will give you better highs, alpine will have better mids...just a tip, if you get the alpine type r components your gonna need an amp for them to sound right
Old Apr 19, 2005 | 10:58 AM
1FASTZ28's Avatar
Ok then I am planning on keeping the stock setup as far as amp and head unit ect. just want to replace the speakers, what would you guys recommend to sound the best with this.
Old Apr 19, 2005 | 11:06 AM
i wnet with the infinity components (6000cs), got them from circuitcity, i love them, there really clear, i have them running off the stock amp, the rear speakers are stock, there blown but i adjust the fade more to the front so it helps with the distortion of the stock rear speakers
Old Apr 19, 2005 | 09:50 PM
1FASTZ28's Avatar
Did you just cut the two wires and wire them to the two wires on the new speakers or did you follow the steps in the Sticky Forum on changing Monsoon speakers and wire the tweeter and woofer seperate.
Old Apr 19, 2005 | 10:48 PM
i just swapped out the tweeters and midranges...no special wiring, also i didnt use the cross overs that the infinitys came with
Old Apr 21, 2005 | 10:35 AM
1FASTZ28's Avatar
Where did you get them from and about how much did you spend for them. I am assuming since you have a Firebird is why you didn't have to wire them any different I think the wireing is a little different for the Camaro, I will have to check into that, but I think I am going to go the Infinity route, thanks everyone.
Old Apr 21, 2005 | 11:31 AM
got them from circuit city for $200, i listened to both the infinity's and the alpine type-r components, i love alpine, but the infinity's highs were a lot clearer and defined than alpint
Old Jun 12, 2005 | 05:36 PM
GPz1100's Avatar
Any thoughts or considerations or personal experience with the Type X speakers .. ie SPX-177R
Old Jun 14, 2005 | 03:09 PM
Martingale's Avatar
I just put the Type S 6 1/2 components up front in my car along with Type R 6 1/2" coaxials in the sail panels powered by an Alpine 55x4 amp. I must say that if I could do it all over again I wouldn't go with these speakers. The mids are okay buy the highs sound flat. I think they are a soft dome tweeter which I don't like. I think the $99 Polks in my Mustang getting 40 watts sound just as good. Alpine's amps are GREAT but I'm not a huge fan of these speakers.
Old Jun 14, 2005 | 07:34 PM
GPz1100's Avatar
Originally Posted by Martingale
I just put the Type S 6 1/2 components up front in my car along with Type R 6 1/2" coaxials in the sail panels powered by an Alpine 55x4 amp. I must say that if I could do it all over again I wouldn't go with these speakers. The mids are okay buy the highs sound flat. I think they are a soft dome tweeter which I don't like. .
Did you listen to them before getting the type S's?
Why not go with a matched set of Type R's all around?
