interior lights don't work...
The BCM is a black box about the size of a small paperback book mounted under the dash behind the glovebox. It controls a number of functions besides the courtesy lights (alarm system, keyless entry, etc.).
Check the wires before replacing the BCM (it's not cheap and has to be programmed to your car). There are three plugs on the BCM - a 6-pin green, a 6-pin black, and a 32-pin blue. The power feed for the courtesy lights is on the dark blue with white stripe wire in the black connector and the ground is on the white wire in the large blue connector. The ground should be available anytime the lights would be on. The power will vary - the BCM gradually decreases the voltage to create the dimming effect.
The BCM actually draws power from several sources: a fusible link in the engine compartment, the PWR ACCY fuse, the GAUGES fuse, the COURTESY fuse, and the accessory circuit from the ignition switch. The RADIO fuse is actually in the output from the BCM as part of the RAP circuit (i.e. power comes to the BCM through the fusible link and then is routed back to the fuse box for the RADIO fuse).
The things that do work are; hatch release, alarm, and retained accessory power. And my interior lights and power door locks don't work. So I don't really know what's going on with this BCM. I'll just take it to my mechanic and see what he thinks.
