Help Please: head light shakes while driving
Old May 18, 2005 | 08:15 AM
ramairbrc's Avatar
Default Help Please: head light shakes while driving
My 1998 TA has 90,000+ miles, and I'm begining to notice that the right side headlight jiggles or bounces with the movement of the car. I inspected both light assemblies to compare their "rigidity" and I noticed that the right side has "play" where the motor arm contacts the back of the headlight unit. Is there a bushing back there that can be replaced? Is there a part number? Is there a fix for this?
Old Jun 3, 2005 | 07:44 PM
JasonWW's Avatar
Just compare the little plastic buttons and such from the other side to the side jiggling. Sometimes a small plastic "cushion" will break off Also look at the arm on the motor. It will rotate until it hits a plastic stop piece. Make sure it's still there and not damaged.
Old Jun 5, 2005 | 01:10 AM
x phantom x's Avatar
STF veteran / 10 second club
The headlight motor is really poorly designed, and consists of a gear inside a plastic shell, with a plastic cap basically glued on. Sometimes that cap becomes loose (or even comes off), allowing the headlight to flap in the breeze.
If it isn't what JasonWW said, remove the headlight motor, and inspect it. That will most likely be the problem (if it isn't the lil plastic bump-stop).
Old Jun 5, 2005 | 02:55 AM
2MuchRiceMakesMeSick's Avatar
Common problem on the flip up lights.
https://ls1tech.com/forums/showpost....1&postcount=19
Old Jun 5, 2005 | 04:01 AM
JasonWW's Avatar
That's a seperate problem.
