Electronic Traction Control Question
Old May 19, 2005 | 04:06 PM
BigKahuna327's Avatar
Default Electronic Traction Control Question
What years of the Camaro SS came with the Electronic Traction Control switch where you could turn it on and off on the dash??
Old May 20, 2005 | 07:31 AM
WhiteBird00's Avatar
Ungrounded Moderator
All of them - if you have traction control then you have a switch. Even the V6 models equipped with traction control have the switch.
Old May 22, 2005 | 02:07 AM
sp00rkz's Avatar
yep, my v6 has got a TCS switch on my dash
Old May 22, 2005 | 06:03 AM
2MuchRiceMakesMeSick's Avatar
All of them have the option available from the dealership. Ive seen some v6s (firebirds) that have traction control but dont have the TCS switch above the radio.
Old May 22, 2005 | 06:51 PM
XLR8TOR's Avatar
How do they do that? Install a different ABS controller or something?
Old May 23, 2005 | 07:54 AM
Sorry, traction control is a factory installed option only - it can't be added at the dealership. The TCS consists of a different brake pressure modulator valve (BPMV) than the standard ABS version; an electronic brake and traction control module (EBTCM); different wheel speed sensors in the back; an electronic acceleration control module; and different hydraulic lines plus the different wiring to connect it all. This is because the standard ABS system has only three hydraulic circuits - one for each front wheel and a shared one for both back wheels. A TCS equipped vehicle has a four circuit hydraulic system - each wheel gets its own circuit.
If there's no switch, there's no TCS (or ASR on Camaros). If in doubt, check for option code NW9 on the door panel.
