dimonds or jls
Old May 26, 2005 | 05:09 PM
kingofbass's Avatar
Default dimonds or jls
ok im on a debate shold i buy 2 12" dimonds m6 for about 150 a peice thay push 800 rms or go with a other maker like jl for about $600 dollers i can get one 12 w6v2 thats about 800rms and i will have a hifoncs amp that pushes 1800 watts at a 1 ohm load what do you think
Old May 26, 2005 | 10:34 PM
Dal1as's Avatar
Get the Diamonds. I'm running a single M6 in a .6 cubic foot stealth box and it suprised the hell out of me. The quality will be similar between the two.
Old May 27, 2005 | 04:37 PM
unredeemed's Avatar
Diamonds, Adire, Peerless, or Dayton. IMO JL is overrated and overpriced.
Old May 27, 2005 | 04:40 PM
Daley's Avatar
In all my years of working on a professional level with everything from Pro audio to car audio, I've never seen a driver 'push' wattage, yet I hear and see this quite a bit - can someone please explain this to me?
Old May 27, 2005 | 07:19 PM
Richiec77's Avatar
Down Boy, DOWN.
I would say to go with what has been recommended. Also check out Adire Audio. (unredeemed mentioned theses)
http://www.adireaudio.com/Mobile/index.htm
They have some awesome subs for the Money (Now they are strating to charge more Though)
It seems that you are set on the HiFonics amp. 1800w is alot of power.
1 10" in a stealth enclosure is pretty Loud. Suprisingly loud. 2 12" with that much power will slam pretty hard.
What are you going for; Street Bass or Compition Levels?
Old May 27, 2005 | 07:51 PM
Daley's Avatar
So you understand what I'm talkin about then, don't ya Richie?!?
Old May 29, 2005 | 12:17 AM
kingofbass's Avatar
well my friend has 2 12 m6's with a hifonc amp but the amp is 1500 not 1800 but ive never herd any better if he turned it up he scared and never turns it up but his spl and sq is extrmley great i would be going for comp level but i dont want everything sounding like crap i care more about sq then spl
Old May 29, 2005 | 12:35 AM
Richiec77's Avatar
Go for it. Will Probably like them since you have heard them 1st Person.
Also, what Kind of music does your friend listen too? Is it the same as what your Buddy listens too? If so then just demo his. That should make up your mind for sure.
Old May 30, 2005 | 11:32 AM
02Z28LS1's Avatar
what, you don't know what "pushing watts" in a sub is? when a sub is rated for 800 watts, it "pushes" that power when the cone moves up and down.....jeez, get with it, man!!!
Old May 30, 2005 | 02:56 PM
Daley's Avatar
So is that why the cone becomes blurry when I crank it up? Is that those watts just being "pushed" right off the speaker cone? Thanks for the explanation 02Z28LS1 - I've been so confused for such a long time! See, just another reason to love LS1Tech!!
Old May 30, 2005 | 07:48 PM
kingofbass's Avatar
well i think im going with the dimonds but first i need money time to puch the work clock
