Has anyone put subs in the rear seat locations
Just like the title says. has anyone done this yet. id like to see some pictures if they have. As I am in the process of finishing mine up in the next couple days. 2 JL 12's and 2 amps with a cap. IM going to make it as stealth looking as possible with alil bit of some some =)
heres the car...
![](http://img.photobucket.com/albums/v482/svc707/wheels.jpg)
still working on the enclosure but got a rough idea already on how we are going to seal the glass/resin with the mdf. I already had the sub in the back seats but it was just thrown in there, but had the last two days off to mess around, i wanted to clean it up and take my amps off the gas tank....
heres the car...
hey man, i built a box for my back seats in my v6. it looked real nice, i took out my seats and had it come straight up from the flore to the cup holders and go at an angle all tha way up to where it drops off.its easy if you just make a rectangle box that goes over that hump and make some panels to make evorything flush. mine went all tha way across and ran with the angles of the side. i have some pics layin around somewhere if i can find em ill send em to ya.
i had something pretty much like that in my old second gen firebird. but mine was uglier.
6 cubic feet with downfiring 2 kicker 15's. it absolutely slammed...
i too have been considering a rear seat delete enclosure in my '98, i've been told you will lose some output due to the loss of the cabin gain you get with the subs in the rear, but i've been told low frequencies and subtle little tones and whatnot are more apparent. most likely cause the subs are that much closer to you.
i can deal with having a lower output with the subs in the rear seat location if it means i can retain t-top and grocery storage in the rear. also i dont like the idea of sooo much wieght in the *** end.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by Richiec77
Very Nice. Good looking Fiberglass work.
and yeah, i couldnt see putting all the weight on the very end of the *** of the vehicle. took it out for a ride and my friends that heard me sub before were like WTF
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
oh yeah best of all guess how much $$$ im in this.... NOT EVEN $200 just barely with extra supplies to start another one
Originally Posted by rufretic
That looks like its gonna be really nice. I would try something like that but it looks pretty heavy. Do you have any idea on weight?
I'm might try a single 15" P.R. enclosure in the Future. I really like how those model up compared to a Ported enclosure.
If you have access to a Belt sander, Smooth the edges out. Would look nice.
Round off the Corners to get rid of the sharp point.
If you want a good trick, Get some Really heavy Construction Paper, or some cardboard like what HU come in. Thinner than the Carboard in the pic. Cut it to make Trim pieces for the Sides. That would be a nice touch.
Just trim it till the paper looks good, Trace to MDF, Sand and trim the MDF to fit. Leave a tinny gap for carpet to fit. Pretty easy once you try it.
For the Sides, use a bevel cut to mate up on the Sub face. smoothe the cut edge, but the flat part against the Face leave as is.
Then, Pull the Box out, if you can, Sand that 90 deg back edge so the box sits flatter. The Bottom Front edge.
Nice Box, and Fiberglass work. Just giving you ideas of how to finnish it too look really nice. Keep up the Good Work.
alot of tips but too lazy right now =) that 90deg on the botom front lip is there for a reason. its meant to hold the box up at the angle it is in kinda sorts. and the leg, is what ill call it, sits right on the metal that the seat bolts to basically the box does not move the way its built. i dont have a sander but when it gets carpeted next week or so it will be smooth and then i will be build a face plate that actually hides all of it
thanks for all the kind words tho
