Got XM in, not as clear as a CD, normal?
Not a good place, the metal panel would jam the signal.
XM's and Sirius's signals are not CD quality. digital just means digital. Uncompressed full spectrum audio direct from a CD is 10 megs per single minute of audio. MP3's are still digital, however a compressed form which actually removes aspects of the music that are inaudible to most people. MP3 quality is less than CD as well as still being digital..
(Its in my Formula's wing.)
https://ls1tech.com/forums/attachmen...chmentid=13633
Couldn't hide the Sony XM01's if you tried! 6" tall bugger, looked like the base to a CB Radio mount.
10-4 cchhrrrkkkkkk
Martingale did you get a chance to move the antenna?
Your sound quality issue has to be one of two things. Either the original audio they are broadcasting is not that good quality, or you are getting noise induced somewhere after the signal is decoded.
Assuming the broadcast quality is there, the problem has to be with your reciever, head unit, or wiring in between.
i mounted my antenna under the plastic windshield cowl. werks pretty good (but then again i'm in downtown chicago) and its mucho stealthy.
Im not sure of the size of the Sirius antenna you have. the Delphi one i had was perfectly shaped to sit right between the two brake lights. on the Z28 spoiler it ran through the spoiler and dropped out on the drivers side.
However the current one i have is on the wrapover. its a tiny one so it doesn't bother me.
i would like to improve the reception if possible to where it never loses signal. in its current location, on cross country trips there are times when the signal will go away maybe a second or two up to a minute so i know it cant be the best spot.
i know the ideal spot would be between the t-tops, but i cant bring myself to put a lumpy bump of any size on the exterior of my rig. not to mention the fact that some lamer vandal would yank it off in a heartbeat.
if i would get better reception by re-locating it inside the rear spoiler i might consider it although it would be a pretty big pain in the ***.
