a/f ratio hooked up to a switch
Old Jun 19, 2005 | 11:19 PM
lilbuddha's Avatar
Default a/f ratio hooked up to a switch
does anyone have instructions to install an a/f gauge to a switch so it can read both o2 sensors?
Old Jun 20, 2005 | 12:46 AM
2MuchRiceMakesMeSick's Avatar
Which a/f gauge. Make sure that you keep 12v on the calibration box or the wideband sensor will go bad because it has to be heated at all times. Might be easier to just buy two widebands because the calibration box is what cost so much, not the gauge.
Old Jun 21, 2005 | 11:42 AM
Kirby's Avatar
It may even be a narrow band sensor. If it is, I could see how it may be possible to connect a 2 stage toggle switch to the system. Down meaning bank 1 sensor and up meaning bank 2 sensor. This may become helpful in diagnosing a misfire problem as I am having right now. My A/F gauge told me my main problem was my passenger side since my gauge is hooked up to the bank 2 sensor. Could be very helpful to switch back and forth. I may look into this.
