disarming factory alarm via aftermarket alarm?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
how would you do this? i found some wiring colors, that factory arm and disarm are the tan and gray wires by the BCM. i've put a multimeter on them and seen 12 volts on the wires when i arm or disarm, but when i try to hook up 12 volts TO them nothing happens. how am i supposed to be doing this?
Ungrounded Moderator
There is no way to disable the factory alarm from an external device such as an aftermarket alarm (i.e. there is no "disarm" signal wire). You can turn off the alarm using the programming instructions in your owners manual. I have posted a copy previously but I'm not in the office right now to have them handy to post again. If you need them I'll post them when I get back to the office.
thanks... i'll look in the owners manual...
also where is the door switch? i want to wire it to turn dome lamps on when disarmed. and how do i keep the factory 2 step door unlock? is there a door lock relay somewhere i need to tap into?
You can approximate the feature by wiring in such a way that the disarm signal unlocks only the driver's door. Then you can use another channel on the alarm to unlock the passenger's door. Not quite the same thing but close. If you want to set this up you will need to connect your alarm's unlock wire to the tan wire at pin B of the 6-pin green connector at the BCM (it's the only tan wire in that connector). This wire goes directly to the unlock side of the driver's door lock motor so your alarm will have to provide a 12V+ pulse.
If you have an extra channel you want to use to unlock the passenger's door then you will need to connect that channel's signal to the gray with black wire in the same 6-pin green connector at the BCM (again, it's the only gray with black wire in that connector). Same as above, this wire goes directly to the unlock side of the passenger's door lock motor so your extra channel signal will have to provide a 12V+ pulse.
